judy 2
#1 Posted : Thursday, July 31, 2008 2:23:27 AM(UTC)
judy 2
You have been a member since:: 7/31/2008(UTC)
the central a/c condenser iced up on the freon line outside now that the ice is gone is there anything that needs to be done to it to keep it from doing it again. Judy 2
SublimeMasterJW
#2 Posted : Thursday, July 31, 2008 5:08:12 AM(UTC)
SublimeMasterJW
Get some coil cleaner and follow the manufacturers directions. A dirty condenser cleaned by the homeowner on a regular basis will help on that electric bill too. The inside coil needs cleaning too but you need to get the non rinse stuff for that. If you have some guages the low side should be around 68 PSI.
gregg
#3 Posted : Monday, August 4, 2008 5:01:06 PM(UTC)
gregg
unit could be low on freon as well, however as stated a clean unit is a must.
judy 2
#4 Posted : Wednesday, August 6, 2008 6:01:13 PM(UTC)
judy 2
thank you for the help,i really just learning about alot of things on the computer sorry about the wait and YES you guys helped alot and i hope you will again in the future judy2
