BeginnerGuy
#1 Posted : Wednesday, July 30, 2008 5:49:27 PM(UTC)
BeginnerGuy
My washing machine was fine the other day...then I tried to was a small load and the machine went kaput. The machine made it through the wash cycle, but it is unable to drain.
I remember the machine spining for a few seconds...then clicking or humming...then nothing...then it would repeat (20 or so times). When I heard that, I thought it was odd behavior.
I unplugged it and plugged it back in...still can't get it to drain. I thought I smelled something burning too.
I haven't yet taken it apart to see what is the problem.
Any ideas where I should start? or should I just buy new? I think the washer was around $400 when I got it.
Thanks.
BeginnerGuy
#2 Posted : Wednesday, July 30, 2008 7:27:51 PM(UTC)
BeginnerGuy
I just tried to get the washer to drain again. With the door open, I turned the dial to spin and held down the door switch. The machine did nothing...but hummed.
Next, I did the same but turned the dial to wash...the machine agitated!
So...I now know the door switch works...and it appears that the motor works.
Side note...I used a bucket to get most of the water out. While doing so, I found a few small pieces of gum and a gum wrapper. Hmmmm.
What do I try next?
#3 Posted : Thursday, July 31, 2008 6:55:07 PM(UTC)
Most likely the drain pump got stuck and has to be replaced. You have to remove the front cover to access the drain pump.
- The part number for the drain pump is AP3160348
Here are the break down diagrams for the Hotpoint washer Model VBXR1060T5WB
Whirlpool Dishwasher Won't Drain Completely, I hear Pump Running... (Dishwasher Repair)
by Guest 4/18/2022 5:39:50 PM(UTC)
Bosch SHU33 dishwasher won't drain when hot just after a wash (Dishwasher Repair)
by Guest 7/12/2021 7:43:33 AM(UTC)
Maytag washer won't drain with clothes (Washer Repair)
by Guest 7/8/2021 3:20:36 PM(UTC)
Bosch dishwasher won't drain, begins cycle, then stops - FIXED (Dishwasher Repair)
by mabradbury 1/17/2019 7:08:25 PM(UTC)
Bosch dishwasher won't drain completely (Dishwasher Repair)
by nathaniel.hoffman@gmail.com 12/25/2018 6:30:47 AM(UTC)
GE dishwasher won't drain after last rinse cycle (Dishwasher Repair)
by autotech1 1/22/2018 9:47:40 AM(UTC)
Dishwasher won't drain (Dishwasher Repair)
by Drummabouy 6/22/2017 6:29:14 AM(UTC)
Washer won't drain (Washer Repair)
by jpowell1978 2/23/2017 5:58:30 PM(UTC)
Dishwasher Won't Drain or Run Cleaning Cycle (Dishwasher Repair)
by Katie L 8/4/2016 2:07:24 PM(UTC)
Bosch Dishwasher won't drain and goes directly to "Clean" Light (Dishwasher Repair)
by ed3120 6/4/2016 4:40:01 AM(UTC)
by brokenge 2/18/2016 2:32:59 PM(UTC)
Frigidaire dishwasher won't drain (Dishwasher Repair)
by kohanz 12/4/2015 9:35:55 PM(UTC)
Washer won't drain!!! (Washer Repair)
by Bdelay24 11/5/2015 6:27:01 PM(UTC)
Dishwasher won't drain! (Dishwasher Repair)
by Crafter_Man 10/12/2015 4:30:35 AM(UTC)
Top load washer won't drain... (Washer Repair)
by Gigler90x 7/28/2015 7:38:09 PM(UTC)
