I HAVE NO GAS COMING OUT OF OVEN TUBE.THE IGNITER WORKS FINE AND THE BRIOLER/TOP RANGE ARE OK.DO I NEED VALVE?:confused:
You may have a bad glowbar, check resistance, should be between 50-150 ohms, if not you glowbar is bad.
Is that ignitor so bright that you cannot look at it? Or does it have a mellow orange color. If it looks orange it probably is weak. It needs to put out 3.5 amps to open the safety valve and release the gas. If it is weak you can sometimes kick the stove and it will ignite. Change the Ignitor ![washing machine picture update.jpg washing machine picture update.jpg](/resource.ashx?p=386&b=1) SublimeMasterJW attached the following image(s):
