Cam2008
#1 Posted : Wednesday, July 30, 2008 2:12:11 PM(UTC)
Cam2008
We have looked at the machine and can't tell from the 1 piece bottom what to do to repair the "out of balance" behavior the machine is exhibiting. Any ideas what the cause might be and whether a schemtic is available on-line?
SublimeMasterJW
#2 Posted : Wednesday, July 30, 2008 2:32:44 PM(UTC)
SublimeMasterJW
The older machines you could put a block under the main pully to lift the tranny and examine the snubber pad and maybe reposition it. Also look for a broken main spring.If the pad is worn out then the washer will be all over the place.
