I have a leak on the bottom of my tub at the location inside the red rectangle (see pic). You can actually see a water droplet in the smaller rectangle. From this point the water is slung around the inside of the cabinet and leaks out the bottom. What is the recommended repair parts for my model? Do you have instructions for removing and installing? Any special tools or hints? How difficult is this repair? I have repaired my clothes dryers before but have never worked on a washer. Thanks for your help. miceec attached the following image(s):
You have a bad tub seal and bearing. Rather a time consuming job and you will need the special tub spanner wrench. Go to web site www.applianceaid.com for info on this repair.
