miceec
#1 Posted : Tuesday, July 29, 2008 6:40:16 PM(UTC)
miceec
I have a leak on the bottom of my tub at the location inside the red rectangle (see pic). You can actually see a water droplet in the smaller rectangle. From this point the water is slung around the inside of the cabinet and leaks out the bottom.
What is the recommended repair parts for my model? Do you have instructions for removing and installing? Any special tools or hints?
How difficult is this repair? I have repaired my clothes dryers before but have never worked on a washer.
Thanks for your help.
miceec attached the following image(s):
#2 Posted : Wednesday, July 30, 2008 8:37:48 AM(UTC)
You have a bad tub seal and bearing. Rather a time consuming job and you will need the special tub spanner wrench. Go to web site www.applianceaid.com for info on this repair.
Maytag washer leaks on power wash cycle (Washer Repair)
by homeland1984 8/1/2020 8:44:37 AM(UTC)
Maytag Washer leaks at bottom tub seal (Washer Repair)
by Stilltrying 6/22/2015 5:52:31 PM(UTC)
Maytag washer leak (Washer Repair)
by joeblowsky 3/16/2015 12:10:39 PM(UTC)
Maytag washer leaking (Washer Repair)
by kpks26 2/5/2014 1:16:48 PM(UTC)
Maytag Washer Leaking (Washer Repair)
by scottlassy 12/11/2012 7:46:32 PM(UTC)
Maytag Washer Leak repaired, but resulted in loss of spin (Washer Repair)
by Repair Gone Wrong 2/21/2012 11:21:14 AM(UTC)
by kaclark7 2/20/2012 5:03:39 PM(UTC)
Maytag Washer leaks (Washer Repair)
by A00446849 2/20/2012 9:31:31 AM(UTC)
Maytag Washer leaks on side of drain hose (Washer Repair)
by della 12/17/2011 10:34:04 PM(UTC)
maytag washer leaks (Washer Repair)
by kramler92 12/7/2011 4:47:43 PM(UTC)
Maytag Washer Leaking Water into Tub (Washer Repair)
by mightypasta 11/21/2011 8:55:22 AM(UTC)
Maytag washer leak at tripod bolt (Washer Repair)
by rrando 5/19/2011 5:43:10 AM(UTC)
Another Maytag Washer leaky tub parts question (Washer Repair)
by sbracer 2/22/2011 1:40:18 PM(UTC)
Maytag Washer leaks at bottom (Washer Repair)
by ronf 10/23/2010 6:07:28 AM(UTC)
Maytag washer leaks on the bottoom (Washer Repair)
by Bummer plumber 9/9/2010 7:56:24 AM(UTC)
