Hi washer will spin only. when you raise lid it stops spinning. spin is all it will do. Need Help Please
Hi Steve,
Does it fill up with water?
Does it drain?
Does the motor run when it should agitate?
not it doesn,t do anything but spin
Looks like the problem caused by no water is coming in. Check the water supply first. Check if 120VAC is coming to the water valve coils (hot & cold) while the water temperature switch is in all possible settings.
Post the results.
