steve bell
#1 Posted : Tuesday, July 29, 2008 5:06:36 PM(UTC)
steve bell
Hi
washer will spin only. when you raise lid it stops spinning. spin is all it will do. Need Help Please
#2 Posted : Wednesday, July 30, 2008 4:56:39 PM(UTC)
Hi Steve,
Does it fill up with water?
Does it drain?
Does the motor run when it should agitate?
steve bell
#3 Posted : Friday, August 1, 2008 4:30:14 AM(UTC)
steve bell
not it doesn,t do anything but spin
#4 Posted : Friday, August 1, 2008 1:57:44 PM(UTC)
Looks like the problem caused by no water is coming in. Check the water supply first. Check if 120VAC is coming to the water valve coils (hot & cold) while the water temperature switch is in all possible settings.
Post the results.
