MMFAIR
#1 Posted : Tuesday, July 6, 2010 5:23:21 PM(UTC)
MMFAIR
about every two or three weeks water stands in the bottom inside my refrigerator under the crisper drawers. It just started this about 3 months ago, my frige does not have an ice maker or water dispenser. What is wrong and how can I fix it
#2 Posted : Wednesday, July 7, 2010 4:55:11 AM(UTC)
I cannot confirm that the following applies but it should be close.
http://frigidaireservicetips.com/pdfs/494_1.pdf
Sounds like the tube that carries the water from defrost down to the drip tray under the unit is plugged and it is dripping into the fresh food section.
Many units drain into a funnel like device at the top back of the fresh food section..
Check that it is not plugged by dust etc. at the drip tray end.
Can often be cleared with compressed air or a turkey baster with some warm water of a flexible wire.
It is a good idea to flush it with a 10 percent bleach solution once it is cleared. This kills any crud growing in the tubing, A turkey baster is handy for this. Just be careful to not overflow the drip tray.
Frigidaire Refrigerator model 253.56602402 issue (Refrigerator & Freezer Repair)
by anitak4242 1/17/2024 8:32:53 PM(UTC)
Frigidaire Refrigerator FRS24XGCB1 (Refrigerator & Freezer Repair)
by Guest 1/1/2024 12:18:22 PM(UTC)
Frigidaire Refrigerator Ice Maker and Water Dispenser not working (Refrigerator & Freezer Repair)
by kehoetj 5/9/2023 3:57:44 PM(UTC)
Frigidaire Refrigerator, not cooling (Refrigerator & Freezer Repair)
by Guest 7/31/2022 11:09:46 AM(UTC)
Frigidaire Refrigerator Fan(s) Inside Cycling On And Off To Get Started (Refrigerator & Freezer Repair)
by JamesDIY 4/28/2022 1:25:48 AM(UTC)
Frigidaire Refrigerator GLHS268ZDS2 (Refrigerator & Freezer Repair)
by Pursue 10/26/2021 2:10:36 PM(UTC)
Frigidaire Refrigerator FFTR1814LW9 (Refrigerator & Freezer Repair)
by Guest 10/11/2021 9:30:20 AM(UTC)
Frigidaire refrigerator handle (Appliance Parts)
by Eastwezt 8/20/2021 10:04:25 AM(UTC)
2003 Frigidaire Refrigerator (Refrigerator & Freezer Repair)
by Guest 6/25/2021 5:52:53 PM(UTC)
Model FRS23H5ASB8 Frigidaire Refrigerator issue (Refrigerator & Freezer Repair)
by Johnnyvirgil 2/15/2021 9:20:33 AM(UTC)
Frigidaire Refrigerator FGHS2631PF4A - Freezer not cold but Refigerator side is fine (Refrigerator & Freezer Repair)
by kwaropay 1/28/2021 9:00:51 AM(UTC)
Frigidaire Refrigerator LGHT1846QP1 - door switch and cabinet cooling (Refrigerator & Freezer Repair)
by BJPrice 10/26/2020 5:28:12 AM(UTC)
Frigidaire refrigerator model # FRT18S6AW9 (Refrigerator & Freezer Repair)
by rlundin@nycap.rr.com 6/29/2020 4:32:36 PM(UTC)
Frigidaire Refrigerator FGHS2644KF1 (Refrigerator & Freezer Repair)
by Shutterbug962 5/23/2020 12:51:57 PM(UTC)
My Frigidaire Refrigerator stopped workin (Refrigerator & Freezer Repair)
by justme0987 4/8/2020 12:18:43 PM(UTC)
