The Temperature Control Does Not Have Any Effect. Set At 46 Degrees Referigerator Temp, 0 Degrees Freezer Temp. Actual Cabinet Temp Is 32 Degrees, Crisper Temp Is 28 Degrees, Freezer Temp Is Minus 15 Degrees. Bad Temp Sensor??
