wnewsome@yourmortgagepeop
#1 Posted : Friday, July 2, 2010 11:01:55 AM(UTC)
I have a Jenn-Air dish washer that is not pumping water through the sprayers. I have checked to see that nothing is clogged and I can hear the inpeller spinning when the machine is on but it sounds like it slows way down as the presure builds and isn't turning fast enough to push water up the sprayers. Any ideas?
#2 Posted : Friday, July 2, 2010 3:31:55 PM(UTC)
Disassemble the pump to access the chopper and seals (#8 & #9 on the diagram) and inspect all parts. Follow the disassembly instructions in the Service manual.
Here are the breakdown diagrams and Replacement parts for JENN-AIR JDB4000AWW Dishwasher - Undercounter | AppliancePartsPros.com
- The seal kit Part number: AP4365097
Jenn-Aire JDS-9865BPD (Oven Repair (including Ranges and Cooktops))
by Guest 1/13/2024 11:53:51 AM(UTC)
Jenn-Air JMW8527AAW display (Oven Repair (including Ranges and Cooktops))
by items 12/12/2023 1:29:40 PM(UTC)
Jenn-air JIS1450DS1 Oven Touch Control - “Start-Button" (Oven Repair (including Ranges and Cooktops))
by Guest 11/6/2023 4:31:59 PM(UTC)
Jenn-Air SVE47500B Cooling Fan Running at Low Temps (Oven Repair (including Ranges and Cooktops))
by hillridge 9/26/2023 9:04:30 AM(UTC)
Jenn-air refrigerator not cooling (Refrigerator & Freezer Repair)
by pke 9/20/2023 4:18:40 PM(UTC)
Jenn-Air Model 88370 (Oven Repair (including Ranges and Cooktops))
by Guest 6/28/2023 7:14:09 AM(UTC)
Jenn-Air 48" Built-in - JS48PPDUDB01 (Refrigerator & Freezer Repair)
by elmariachi 6/8/2023 10:54:42 AM(UTC)
Jenn-Air jfx2597aep2 refrigerator power cycling (Refrigerator & Freezer Repair)
by Jbugg 3/16/2023 7:17:18 PM(UTC)
Jenn-Air JJW9630DDB error 1d11 (Oven Repair (including Ranges and Cooktops))
by tedshred 10/2/2022 8:33:02 AM(UTC)
Jenn-Air JDS9865BDP Control Panel (Oven Repair (including Ranges and Cooktops))
by Bchip-665 1/21/2022 11:52:08 AM(UTC)
JENN-AIR MODEL JGM8130DDM SLIDE IN GAS WALL OVEN (Oven Repair (including Ranges and Cooktops))
by Guest 11/21/2021 5:35:44 PM(UTC)
Jenn-Air stove top infinite switch clicking (Oven Repair (including Ranges and Cooktops))
by JonVahsholtz 11/15/2021 9:11:15 PM(UTC)
Jenn-Air control panel wrong model installed (Oven Repair (including Ranges and Cooktops))
by Guest 11/15/2021 4:50:43 AM(UTC)
Jenn-Air Broiler (JES9800CAB01) (Oven Repair (including Ranges and Cooktops))
by BCT 11/1/2021 9:02:00 PM(UTC)
Jenn-Air spontaneous fire while turned off - JDR8895AAB/S/W (Oven Repair (including Ranges and Cooktops))
by amelanchier 11/1/2021 11:02:50 AM(UTC)
