Popi22
#1 Posted : Thursday, July 1, 2010 9:03:11 AM(UTC)
Popi22
Washer will not agitate or spin on any cycle; however, it will fill and drain. I can hear humming at the beginning of the wash cycle and feel the tub vibrating. The belt moves freely. Thanks for your help.
#2 Posted : Thursday, July 1, 2010 11:54:00 AM(UTC)
Sounds like the problem is a bad speed control board or a bad motor.
Remove the bottom service panel and check for an envelope with the Tech sheet. Perform the diagnosis as described in the Tech sheet.
Here are the breakdown diagrams and Replacement parts for General Electric WSXH208A1WW Washer | AppliancePartsPros.com
Popi22
#3 Posted : Friday, July 2, 2010 7:31:14 AM(UTC)
Popi22
Thanks Gene. I will check for the tech see and let you know how it go.
