ed o
#1 Posted : Monday, June 28, 2010 8:51:59 AM(UTC)
ed o
i was needing info about the defrost system on this maytag the evaporator kepps freezing over i read the post about checking the defrost timer but i dont know if mine has this any help thanks
FridgeDoctor
#2 Posted : Monday, June 28, 2010 9:12:22 AM(UTC)
FridgeDoctor
Groups: Expert
It does and its located in the fresh food section behind the canopy cover. From this control you can test the voltage to the control board, the defrost heater and the termination limit control.
ed o
#3 Posted : Monday, June 28, 2010 10:55:43 AM(UTC)
ed o
thanks for the reply would this part be called the adaptive defrost control board thats all i find if i look in the parts list thanks again
Bosch sprayer channel clip spot weld failed on back wall (Dishwasher Repair)
by Billymons 6/15/2024 5:23:17 AM(UTC)
Solved: Removing microwave unit from wall mounted Oven/Microwave combo (Oven Repair (including Ranges and Cooktops))
by MalikR 6/10/2024 3:04:18 PM(UTC)
Whirlpool WTW7000WD0 - LED on Mobo Blinking after F5/E2 repair (Washer Repair)
by amofiav 5/6/2024 9:11:07 AM(UTC)
Burner heating without cooktop being switched on (Oven Repair (including Ranges and Cooktops))
by nvreds 2/25/2024 10:40:40 AM(UTC)
Need Old Admiral Wiring Diagram (Washer Repair)
by jkuly 1/15/2024 6:09:44 PM(UTC)
replaced auger but ice still not being pushed out of door shoot (Refrigerator & Freezer Repair)
by Guest 10/18/2023 5:41:24 AM(UTC)
Ordered one magnetron, but they sent another (Microwave Repair)
by Demogorgon 9/11/2022 5:14:30 PM(UTC)
in need of a new commercial refrigerator (Refrigerator & Freezer Repair)
by Jake2paul2 8/25/2022 8:48:18 PM(UTC)
Basic things need on Cricket (Trash Compactor Repair)
by Johnalex 7/6/2022 11:07:18 PM(UTC)
new GE range with insulation left in door, burned on use (Oven Repair (including Ranges and Cooktops))
by Hank21 4/21/2022 4:13:03 PM(UTC)
Smells gas as soon as supply is turned on at the wall. (Oven Repair (including Ranges and Cooktops))
by Guest 3/17/2022 7:58:00 PM(UTC)
Tiny burner screws sheared off (Oven Repair (including Ranges and Cooktops))
by ADevan 2/19/2022 4:24:24 PM(UTC)
Jenn Air Range spark module keeps sparking with switch turned off (Oven Repair (including Ranges and Cooktops))
by Guest 2/16/2022 11:48:26 AM(UTC)
Jenn-Air spontaneous fire while turned off - JDR8895AAB/S/W (Oven Repair (including Ranges and Cooktops))
by amelanchier 11/1/2021 11:02:50 AM(UTC)
Water and ice locked on front panel Cannot reset (Refrigerator & Freezer Repair)
by bluefitness 9/13/2021 10:47:50 AM(UTC)
