gehrhart
#1 Posted : Friday, July 25, 2008 3:05:40 PM(UTC)
gehrhart
Fridge Periodically stops cooling which is accompanied by an occasional buzzing sound. If we unplug the unit and let it sit for 8 hours or so when we plug it back in it works fine for a couple weeks. Any ideas, appliances are not my strongsuit but am electrically experienced.
Amana DRB1801AC
Bottom Freezer Refrigerator
#2 Posted : Saturday, July 26, 2008 1:30:49 PM(UTC)
Remove the rear cover and clean the condenser coil. Check if the fan next to the compressor works properly.
At the time when it's acting up, check for frost on the rear panel inside the freezer. Check if the fan inside the freezer works.
Post the results.
Here are the break down diagrams for the Amana refrigerator Model DRB1801AC
