I need to know how to disassemble the ice/water dispenser in the door, to replace a broken switch. Do I pry off the cover? or do I go in through the back, removing many screws?? as well as the door seals.
thanks in advance!!
larry foster
The front panel that says ice/water etc, pops right off, after that is removed, there are 4 screws that hold the assy in place, remove those, remove the rubber pad, by pulling it, it is attached to a square plastic piece that unsnaps, disconnect the wiring and you can get to the switch.
thanks, that works great!!!!
a thousand thanks.
Larry
