larryafoster
#1 Posted : Friday, July 25, 2008 12:29:23 PM(UTC)
larryafoster
I need to know how to disassemble the ice/water dispenser in the door,
to replace a broken switch. Do I pry off the cover? or do I go in through
the back, removing many screws?? as well as the door seals.
thanks in advance!!
larry foster
abadfish66
#2 Posted : Friday, July 25, 2008 12:55:45 PM(UTC)
abadfish66
The front panel that says ice/water etc, pops right off, after that is removed, there are 4 screws that hold the assy in place, remove those, remove the rubber pad, by pulling it, it is attached to a square plastic piece that unsnaps, disconnect the wiring and you can get to the switch.
larryafoster
#3 Posted : Friday, July 25, 2008 1:44:24 PM(UTC)
larryafoster
thanks, that works great!!!!
a thousand thanks.
Larry
abadfish66
#4 Posted : Friday, July 25, 2008 1:48:11 PM(UTC)
abadfish66
Not a problem, good luck
