My ice maker works, however the dispenser will not turn. I hear a loud click if I hold the door open, push the button on the side then push the ice dispenser. Just doing it with the door shut, I hear nothing. The auger will not turn. I tried turning the motor by hand with the ice bucket out. It turns, but not freely. Could it be a motor problem? The motor does not turn at all with the switch.
Check the motor for continuity. Check if there is 120VAC to the auger motor while the dispenser calls for ice. Post the results.
