Matto
#1 Posted : Friday, July 25, 2008 6:23:15 AM(UTC)
Matto
Our dryer dryes the clothes but is all full of sooty black stuff. Our whites are turning grey. Is this a gas problem (bottled gas dryer). Regulator problem to the dryer? Problem with the burner in the dryer? Help I have no repairman available!
#2 Posted : Friday, July 25, 2008 7:59:16 AM(UTC)
Your regulator on the propane bottle may be going bad and allowing the flame to travel up the dryer vent too far. If your front panel has a viewing port, check the flame, if not, you might want to look inside the dryer while it is running. Do this for a short period as the thermal fuse might blow from this viewing.
SublimeMasterJW
#3 Posted : Friday, July 25, 2008 10:46:26 AM(UTC)
SublimeMasterJW
It may be that your dryer is not set up correctly for propane gas. Get your propane supplier to check the dryer out.They should do it as a courtesy.
