Had a power outage in the middle of the night last night. Woke up this morning to the Oven not turning on -- and the 'Oven' light blinks twice and the the 'Heat' light blinks twice. Stovetop portion works...
Tried turning off power to range - but, when turned back on - lights still blink and oven won't work.
After some investigation - it sounds like I need the 'Control Board' replaced?....but please confirm?
If it is the control board, where is it located on the oven? (Would I need to pull this big brute of a thing out?) Any diagrams that would show me where and how to replace?
Thanks for your time!
The "22" error code means "EEPROM error". The correction is to replace the control board. It is located on the back of the range (#8 on the diagram) and the range has to be pulled out of the wall to access it. - The PC board Part number: AP4434213
