BenMA
#1 Posted : Friday, June 25, 2010 8:03:57 AM(UTC)
BenMA
Had a power outage in the middle of the night last night. Woke up this morning to the Oven not turning on -- and the 'Oven' light blinks twice and the the 'Heat' light blinks twice. Stovetop portion works...
Tried turning off power to range - but, when turned back on - lights still blink and oven won't work.
After some investigation - it sounds like I need the 'Control Board' replaced?....but please confirm?
If it is the control board, where is it located on the oven? (Would I need to pull this big brute of a thing out?) Any diagrams that would show me where and how to replace?
Thanks for your time!
#2 Posted : Friday, June 25, 2010 1:08:13 PM(UTC)
The "22" error code means "EEPROM error". The correction is to replace the control board. It is located on the back of the range (#8 on the diagram) and the range has to be pulled out of the wall to access it.
- The PC board Part number: AP4434213
