The Ice maker is not filling with water. I recently purchased the Water inlet valve assembly fro Applicance PartsPros. It did not resolve the problem. The water dispenser is working fine. What should i be looking at to replace? is there a relay in the ice maker or somewhere else? Please let me know, thanks...
thanks for the information Gene. We defrosted the whole refrigerator this past week end and the ice maker is still not working. Like I said before we have replaced the water inlet valve and the red light on the inside is working when you open and close the little flapper. So the next item that i need to look at replacing would be what? I was looking under the Unit parts and see two things, the run capacitator and the relay start. do these have anything to do with the ice maker working properly? Again thanks for you time....
Originally Posted by: Everett Kaiser ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) ...I was looking under the Unit parts and see two things, the run capacitator and the relay start. do these have anything to do with the ice maker working properly?... Sorry for the delay. No, these parts are for the compressor and have nothing to do with the ice maker. Sounds like the ice maker itself is the culprit. - The ice maker Part number: AP3182733
