j.t
#1 Posted : 15 years ago
j.t
I was having my kitchen remodeled and moved the refrigerator toanother room. there was no water supply and we plugged it in. I heard amotor run, but it stopped. later it was moved back to the water supply and we no longer producing any ice. do u have any idea what we need or how to fix this problem? Thank you very much, joan. :mad:
#2 Posted : 15 years ago
Hi Joan,
Do you have the water out of the water dispenser?
If you do, how good is the water pressure?
Here are the breakdown diagrams and Replacement parts for AMANA ARS2664AC Ref - SXS/I&W | AppliancePartsPros.com
j.t
#3 Posted : 15 years ago
j.t
hi gene,
yes, we do have water coming out of the dispencer and the water pressure is good.
pinoy_ako
#4 Posted : 15 years ago
pinoy_ako
its broken the motor when you pull out
j.t
#5 Posted : 15 years ago
j.t
hi pinoy,
you told me that i had to replace the motor. Is that the entire ice maker or is there a seperate motor. Can you please tell me what part I will need to order and where is it located in the ice maker?
Joan
Could someone please help me fix my washer (Washer Repair)
by HopelessNKY 3 years ago
Please help me diagnos refrigerator not cooling (Refrigerator & Freezer Repair)
by beaverislander 3 years ago
Maytag mdb4949sdh0. Can you help me identify what's leaking here? (Dishwasher Repair)
by panzhuli 4 years ago
Dryer timer shorting - help me verify my rationale (Dryer Repair)
by jeromio 5 years ago
Help me find a freezer icemaker (Refrigerator & Freezer Repair)
by michaelproch 6 years ago
Help Me Locate Parts! (Washer Repair)
by lum 7 years ago
Please help me save my keg fridge! (Refrigerator & Freezer Repair)
by Mirage52 9 years ago
Help me check my check balls (Dishwasher Repair)
by drcarl 10 years ago
Help Me (Washer Repair)
by carl1953 10 years ago
New member, help me with my washer please! (Washer Repair)
by FPCD 10 years ago
Please help me change my dryer belt (Dryer Repair)
by jayathorn 11 years ago
Please HELP me with this torsion bar!!!! (Microwave Repair)
by agdodge4x4 11 years ago
Can someone help me with a Bosch soap dispenser (Dishwasher Repair)
by jonjonbear 11 years ago
Help me!!! Oven has no light on control Panel. (Oven Repair (including Ranges and Cooktops))
by Bill uhl 11 years ago
Maytag oven will not bake ... HELP ME!!! (Oven Repair (including Ranges and Cooktops))
by Tarzan95959 11 years ago
