gator68
#1 Posted : 15 years ago
gator68
Freezer and refrigerator had a hard time getting to set temp when opening doors thruout the day and/or loading with groceries.
Checked the condenser fan and was running unbelievably slow (I mean really slow).
I put a small fan behind the refrigerator blowing across the condenser coil.
Works great now but will get a replacement fan soon but hope it provides more revolutions than the current fan otherwise I am in the same boat.
Does anybody know if this low RPM fan is part of the energy saving approach?
applianceman
#2 Posted : 15 years ago
applianceman
Hopefully the fan will fix it but typically the main board causes this. The fan will change speeds. The way this is done is the main board sends different voltages to the fan depending on if it needs to be running high, medium or low speed (it will only have low speed if it has a variable speed compressor). If you have a voltage tester you can test the voltage on the main board. This page should help GE Refrigerator Fan Motor Diagnostics
#3 Posted : 15 years ago
Very good repair site Applianceman, have posted this to the sticky GE refrigerator (GS& PSS) models. People can go to the last page of this sticky for this reference.
applianceman
#4 Posted : 15 years ago
applianceman
Thank you! I hope it helps people with their fan motor problems.
GE refrigerator/freezer side by side (Refrigerator & Freezer Repair)
by Pdynamo 9 months ago
GE refrigerator Ice machine not working. (Refrigerator & Freezer Repair)
by Don718 10 months ago
GE Refrigerator DFE29JSDASS (Dishwasher Repair)
by DOUGZARA 11 months ago
GE Refrigerator “dead” (Refrigerator & Freezer Repair)
by Guest about a year ago
GE refrigerator inside light not working (Refrigerator & Freezer Repair)
GE Refrigerator model# TFF24RBC (Refrigerator & Freezer Repair)
by Kenny67 about a year ago
Dim interior LEDs in GE Refrigerator - update (Refrigerator & Freezer Repair)
by Craigma about a year ago
GE refrigerator/freezer, freezer compartment gets above freezing, ice cubes melt together (Refrigerator & Freezer Repair)
by CT Redmond 2 years ago
GE refrigerator icemaker freezing up (Refrigerator & Freezer Repair)
by Guest 2 years ago
New GE refrigerator not cooling to set temp of 35 (Refrigerator & Freezer Repair)
by VarMan 2 years ago
GE Refrigerator parts (Refrigerator & Freezer Repair)
GE Refrigerator diagnostic mode error codes (Refrigerator & Freezer Repair)
GE Refrigerator Model PSS26LSRF SS (Refrigerator & Freezer Repair)
by Phoenician 3 years ago
GE Refrigerator Model GSS23WSTASS (Refrigerator & Freezer Repair)
by lkrier0612 3 years ago
GE Refrigerator PWE23kskkss (Refrigerator & Freezer Repair)
by bubba1531 3 years ago
