gator68
#1 Posted : Monday, June 21, 2010 5:33:25 PM(UTC)
gator68
Freezer and refrigerator had a hard time getting to set temp when opening doors thruout the day and/or loading with groceries.
Checked the condenser fan and was running unbelievably slow (I mean really slow).
I put a small fan behind the refrigerator blowing across the condenser coil.
Works great now but will get a replacement fan soon but hope it provides more revolutions than the current fan otherwise I am in the same boat.
Does anybody know if this low RPM fan is part of the energy saving approach?
applianceman
#2 Posted : Monday, June 21, 2010 6:54:11 PM(UTC)
applianceman
Hopefully the fan will fix it but typically the main board causes this. The fan will change speeds. The way this is done is the main board sends different voltages to the fan depending on if it needs to be running high, medium or low speed (it will only have low speed if it has a variable speed compressor). If you have a voltage tester you can test the voltage on the main board. This page should help GE Refrigerator Fan Motor Diagnostics
#3 Posted : Tuesday, June 22, 2010 2:47:33 AM(UTC)
Very good repair site Applianceman, have posted this to the sticky GE refrigerator (GS& PSS) models. People can go to the last page of this sticky for this reference.
applianceman
#4 Posted : Tuesday, June 22, 2010 6:31:15 AM(UTC)
applianceman
Thank you! I hope it helps people with their fan motor problems.
GE refrigerator/freezer side by side (Refrigerator & Freezer Repair)
by Pdynamo 6/20/2024 6:20:43 PM(UTC)
GE refrigerator Ice machine not working. (Refrigerator & Freezer Repair)
by Don718 5/6/2024 11:45:46 AM(UTC)
GE Refrigerator DFE29JSDASS (Dishwasher Repair)
by DOUGZARA 4/24/2024 9:43:25 AM(UTC)
GE Refrigerator “dead” (Refrigerator & Freezer Repair)
by Guest 12/3/2023 8:03:32 AM(UTC)
GE refrigerator inside light not working (Refrigerator & Freezer Repair)
by Guest 11/18/2023 10:01:46 AM(UTC)
GE Refrigerator model# TFF24RBC (Refrigerator & Freezer Repair)
by Kenny67 11/3/2023 8:29:39 PM(UTC)
Dim interior LEDs in GE Refrigerator - update (Refrigerator & Freezer Repair)
by Craigma 11/3/2023 12:37:37 PM(UTC)
GE refrigerator/freezer, freezer compartment gets above freezing, ice cubes melt together (Refrigerator & Freezer Repair)
by CT Redmond 7/2/2023 1:59:53 PM(UTC)
GE refrigerator icemaker freezing up (Refrigerator & Freezer Repair)
by Guest 7/1/2023 6:40:00 AM(UTC)
New GE refrigerator not cooling to set temp of 35 (Refrigerator & Freezer Repair)
by VarMan 6/16/2023 5:05:53 PM(UTC)
GE Refrigerator parts (Refrigerator & Freezer Repair)
by Guest 6/5/2023 7:31:51 AM(UTC)
GE Refrigerator diagnostic mode error codes (Refrigerator & Freezer Repair)
by Guest 1/22/2023 10:11:53 AM(UTC)
GE Refrigerator Model PSS26LSRF SS (Refrigerator & Freezer Repair)
by Phoenician 8/14/2022 10:03:28 AM(UTC)
GE Refrigerator Model GSS23WSTASS (Refrigerator & Freezer Repair)
by lkrier0612 7/18/2022 6:18:04 PM(UTC)
GE Refrigerator PWE23kskkss (Refrigerator & Freezer Repair)
by bubba1531 4/14/2022 6:47:57 AM(UTC)
