gwalia
#1 Posted : Wednesday, September 5, 2007 3:31:48 PM(UTC)
gwalia
My Kenmore Elite washer started leaking and I notied that front seal was shredded. Ordered the part from here, part no. AP3128710 (8181850). Took the shredded seal out and it seemed like it was held in by a clamp. But trying to put new seal on has been a challenge! I am trying to just sort of place it around the border and there is not enough space to make it fit all around. Any easier way to do this or do I need to take apart some more parts? Its the side which faces inside the washer which is tricky. I just can't get it secured tight around the border!
Any tricks or ideas??
ggdave
#2 Posted : Sunday, September 9, 2007 9:45:43 PM(UTC)
ggdave
I did this repair 9 months ago. exact steps are a little hazy, however I did it with minimal tear down. access was thru the bottom access cover and door opening. i did remove the 2 screws at bottom of front cover. if memory serves me correct, there is a large hose style clamp on the tub side. and a spring clamp at the door side. i removed the tub side first. really dont remember if i put the tub or the door side on first:confused: remember, that if you have a hard time getting rubber over liped metal, a little dish soap works miracles. good luck
