k_cool
#1 Posted : Sunday, June 20, 2010 11:54:42 AM(UTC)
k_cool
My GE side by side ice dispenser lights have been flaky for a couple of months. They would go off and not dispense but pressing the lever again would usually make the dispenser work. However today, the lights stopped totally working and no water is dispensed. I removed the panel behind the dispenser to 'see' if anything is wrong but could not notice anything amiss. Not sure what the problem is and will appreciate feedback. Thanks.
k_cool
#2 Posted : Sunday, June 20, 2010 3:02:16 PM(UTC)
k_cool
I need to clarify that the ice maker is making ice. No problem with that. Thanks.
k_cool
#3 Posted : Thursday, June 24, 2010 9:09:07 AM(UTC)
k_cool
Can somebody knowledgeable please reply? I note that persons like Gene have been very helpful.
We are hurting and will appreciate some guidance.
Thanks.
#4 Posted : Thursday, June 24, 2010 1:13:18 PM(UTC)
Sorry for the delay.
The ice/water dispenser in you refrigerator is operated by the main control board which is located on the back of the refrigerator. The symptoms you described very likely leading to a faulty main control board.
- The main control board Part number: AP4436216
Here are the breakdown diagrams and Replacement parts for General Electric GSS25LGMAWW Refrigerator | AppliancePartsPros.com
P.S. I'm assuming the model number you posted GS525LGMAWW, should have "S" instead of "5".
k_cool
#5 Posted : Friday, June 25, 2010 9:03:54 PM(UTC)
k_cool
Thank you Gene. I will order the part. I seem to have another problem. Initially I assumed that the circuit board behind the water dispenser was the problem. While checking it, I accidentaly removed the ribbon cable out the chip on the board. Now it does not want to go back. Is there an easy way to put it back. I hate to buy that board also since the fridge is about 9 years old and do not want to spend so much. Your advice is appreciated. Regards.
#6 Posted : Sunday, June 27, 2010 12:14:47 PM(UTC)
Sorry, never took it apart.
k_cool
#7 Posted : Monday, June 28, 2010 7:43:26 PM(UTC)
k_cool
Thank you. Can you please tell the part number if I had to replace this also.
Thanks.
#8 Posted : Wednesday, June 30, 2010 1:42:19 PM(UTC)
- The dispenser control board Part number: AP3140374
- The interface display assembly Part number: AP3206192
