angboule
#1 Posted : Friday, June 18, 2010 10:05:31 AM(UTC)
angboule
I started a load and left the house. i returned home to find water in the bottom of the drum and most of the clothes only partially wet. I held the start and cancel button down together and received E59. After researching this it states that it could be the motor, the tub bearings, or the speed control board. I have also found some people who have changed out the door lock assembly and it has worked fine. well going through tests, i removed the belt and the motor pulley does spin. the tub pulley does not spin and seems to be locked in place. how do I check the tub bearings? do I still need to go through the rest of the test and check the pin ohms?
#2 Posted : Friday, June 18, 2010 2:27:57 PM(UTC)
You should be able to move the tub pulley manually. If it does not move then the problem can be a bad bearing or a foreign object between the inner and outer tubs.
Here are the breakdown diagrams and Replacement parts for FRIGIDAIRE GLTF2940ES2 Frigidaire/washer | AppliancePartsPros.com
angboule
#3 Posted : Monday, June 21, 2010 10:46:12 AM(UTC)
angboule
So do I pretty much just take the tub apart and go from there?
#4 Posted : Monday, June 21, 2010 12:35:16 PM(UTC)
That's right but it's not that simple.
E59 Error Code, No Tach Signal in 3 sec (Washer Repair)
by Joseph A Stanko 11/29/2012 5:15:19 PM(UTC)
