haverhillguy
#1 Posted : Friday, June 18, 2010 8:46:42 AM(UTC)
haverhillguy
Hi - I don't know the age of the unit, but all of the sudden the fridge has started shutting itself off - when this happens both the fridge and the freezer shuts down and the digital display reads "-" "-" for both the fridge and freezer. It has done this 3 times now. First time was about a month ago, then recently it did it withing maybe 3-4 days.
Can someone help me diagnose this?
FYI we live in a very humid tropical environment so I am wondering if the defroster components are overheating - but agian I don't know anything about diagnostics on these things.
Thanks so much!
FYI I have a multimeter if that helps
#2 Posted : Friday, June 18, 2010 11:40:00 AM(UTC)
Perform the troubleshooting as described in the Service manual.
Here are the breakdown diagrams and Replacement parts for AMANA ABD2233DES Ref - Bottom Mounts | AppliancePartsPros.com
haverhillguy
#3 Posted : Friday, June 18, 2010 3:42:21 PM(UTC)
haverhillguy
Thanks for the manual reference. Which test should I run? The problem is the issue is intermittent and only seems to happen a number of days apart. I am thinkign if I run the on-board test they will check out okay and not show a part that is failing.
Thanks for your input
#4 Posted : Saturday, June 19, 2010 11:01:11 AM(UTC)
If the problem is really intermittent then there is not much what can be done. You should wait until it will do it more often.
