I attempted to replace my dryer belt and found that my idler pulley was laying on the deck. How do you reassemble the idler pulley, if possible. Thanks:confused:
The idler pulley plugs into the slots on the dryer base. Gene. Gene attached the following image(s):
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) The idler pulley plugs into the slots on the dryer base.
Gene. No way! Am I supposed to stretch the spring to a point above the motor??
Here is the Whirlpool belt diagram: ![UserPostedImage](http://www.appliancepartspros.com/img/dryerbelts/wpl-dr-blt-dgrm.gif) Gene.
