I attempted to replace my dryer belt and found that my idler pulley was laying on the deck. How do you reassemble the idler pulley, if possible. Thanks:confused:
The idler pulley plugs into the slots on the dryer base. Gene. Gene attached the following image(s):
Originally Posted by: Gene The idler pulley plugs into the slots on the dryer base.
Gene. No way! Am I supposed to stretch the spring to a point above the motor??
Here is the Whirlpool belt diagram: Gene.
