vngray
#1 Posted : Thursday, June 17, 2010 7:37:38 AM(UTC)
vngray
clothes get so hot you can hardly touch them .lint screen is clean and the exhaust is not clogged
#2 Posted : Friday, June 18, 2010 2:30:06 AM(UTC)
Replacement parts for General Electric DVLR223ET0WW Electric dryer | AppliancePartsPros.com
Could be you have a grounded element.
The element sags/breaks and touches the frame, it then runs all the time and the thermostats cannot regulate it.
Unplug the unit.
Remove the wires from the heating elements.
Be sure to mark them so you know where they go.
Measure each element, usually around 10 to15 ohms.
Then measure from each connector to the frame/case, should be infinite ohms (open)
If not you have a grounded element.
GE electric dryer (DCVH680EJ1MS) Stops 2 mins. Into Cycle (Dryer Repair)
by bjohns610 9/30/2019 2:15:08 AM(UTC)
GE electric dryer rotating switch (Dryer Repair)
by pamelaw72 8/21/2019 2:39:50 PM(UTC)
GE Electric Dryer Shuts Off Mid-Cycle (Dryer Repair)
by Dynocon 10/22/2015 5:20:00 PM(UTC)
GE Electric Dryer - Belt / slide fix, did I break something? (Dryer Repair)
by bmilcs 8/23/2015 1:23:57 PM(UTC)
GE electric Dryer running then had a smell and stopped (Dryer Repair)
by DDEAN 5/12/2015 7:52:33 PM(UTC)
GE Electric Dryer won't start (Dryer Repair)
by brosnan 12/13/2014 2:08:12 PM(UTC)
GE Electric Dryer (Dryer Repair)
by josiec 8/20/2013 12:38:26 PM(UTC)
GE electric dryer won't heat up (Dryer Repair)
by jrogers 7/4/2013 11:55:26 AM(UTC)
GE Electric Dryer suddenly got loud (Dryer Repair)
by Newbie2 12/15/2012 6:58:35 PM(UTC)
GE Electric Dryer - Won't Start (Dryer Repair)
by stockejj 10/31/2012 8:38:36 AM(UTC)
GE Electric dryer no start (Dryer Repair)
by TravisG 4/12/2011 1:30:52 PM(UTC)
GE electric dryer wont start (Dryer Repair)
by cojay 3/13/2011 6:38:17 PM(UTC)
trouble replacing belt GE Electric Dryer (Dryer Repair)
by lshelly40 2/6/2011 11:23:33 AM(UTC)
GE Electric dryer, no heat (Dryer Repair)
by khoshkkon 11/25/2010 10:38:07 AM(UTC)
Ge Electric Dryer Start Switch (Dryer Repair)
by lwpeters52@hotmail.com 10/16/2010 2:06:48 PM(UTC)
