jossey1
#1 Posted : Tuesday, June 15, 2010 4:38:06 PM(UTC)
jossey1
i ordered the timer knob and wanted to install it. i need to take off the front panel to replace the timer knob. please tell me how to do that. kenmore washwer 417.29042992. make WCI part number 131446203
sidfink43
#2 Posted : Friday, June 18, 2010 6:02:27 AM(UTC)
sidfink43
This service manual should show you how to do what you want to do.
http://frigidaireservicetips.co..._TumbleActionWashers.pdf
AnotherFineMess
#3 Posted : Saturday, November 2, 2013 8:18:10 PM(UTC)
AnotherFineMess
@sidfink43
Any possibility you may have a working link to the above referenced service manual? PLEASE?
The Timer stem got bent during a move on our heretofore perfectly working 417.29042992.
I've already broken the teeth off the knob retaining ring trying to remove the front panel. I'm in deep need of a service manual before I rack up more expense than I can afford to fix.
Thanks in advance for your time & consideration.
sidfink43
#4 Posted : Sunday, November 3, 2013 3:46:43 PM(UTC)
sidfink43
If you will post your model number so I can see exactly which machine you have I can probably give you a current link to a service manual.
AnotherFineMess
#5 Posted : Monday, November 4, 2013 1:32:36 PM(UTC)
AnotherFineMess
I can hardly believe my eyes that you are still here! Thank you kindly for responding to my request.
To answer your question, I have a Kenmore (built by Frigidaire) front loading washer model 417.29042992.
Every link I've discovered thus far, are no longer working.
In desperation, I registered here to ask if you still have a copy. Frankly, I wasn't expecting a reply on a three year old post.
Thank you, Thank you, Thank you for besting all the odds.
A most pleasant day to you! :)
Hooray! I found it!!!
Link to above mentioned manual:
http://www.emaservicetips.com/p..._TumbleActionWashers.pdf
Thank you kindly, sidfink43, for your time & consideration. It's appreciated.
