james ngo
#1 Posted : Monday, June 14, 2010 4:38:00 PM(UTC)
james ngo
I have a maytag duet washer and gettinga f71 and f70 sometimes i opened up the top panel and wiggled some of the connectors and turned it on and was able to wash 4 loads without any issues and a few days later im getting the codes again but its spuratic disconnect the power and it will start a cycle and spin and stuff but after a few minutes it will give the f71 code again? what can i do to fix it? Ive done the research for it and i dont think its the ccu or interface because if it works sometimes, I believe its a communication issue like loose connections. Any suggestions?
#2 Posted : Tuesday, June 15, 2010 3:10:20 AM(UTC)
I would take apart each connector, look for loose pins, then spray each one with non-residue contact cleaning spray available at Radio Shack.
