I have a maytag cenntenial dryer. It works fine except the timer wont advance. Not in any mode. Cleaned dryer vent in dryer, all the way outside. any advice would be helpful. I would also like a model specific manual. Thanks
You either have a blown open timer motor, a bad internal clutch, or a bad timer gear train. Probably easiest to just treplace the timer.
