I bought part # AP4298908 from this web site & one of the valve outlets leaks. It is a "press fit"/ insertion connector with an O-Ring holding the line in the valve. I tried to remove the leaking water line & ruined it. Any suggestions as to removing the others without damaging them? I could cut them off but two are not long enough.
They are replacing the valve N.C. & the customer service has been great.
Thanks in advance,
LT
