Ashes2
#1 Posted : Saturday, June 20, 2009 9:57:06 PM(UTC)
Ashes2
I have replaced the thermostat, defrost element, and timer. The freezer is cold, but not freezing. The fridge is cool but not cold. the compressor is HOT to the touch. The fans are all working. There is a layer of frost on the elements when it is supposedly freezing that melts away when it goes into defrost. One day last week the food in the bottom of fridge was frozen--next day it was luke warm. What to check next?
#2 Posted : Sunday, June 21, 2009 12:59:12 AM(UTC)
Model Search
Here is your wiring diagram
http://manuals.frigidaire.com/p...f/Anderson/218909401.pdf
I am assuming the thermostat you replaced was the defrost thermostat.
It sounds like you temperature control thermostat is not operating correctly.
Below is a link with info on how to check the temperature control
Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
Note that it may check OK because it sounds like it has gone intermittent.
I am also assuming that the layer of frost you saw on the evaporator coils was fairly even over the whole evaporator. If it was just in one area, where the freon enters the coil, it could be you have a low freon condition.
Ashes2
#3 Posted : Monday, June 22, 2009 7:34:54 AM(UTC)
Ashes2
Thanks. I think it is a mixture of both. Can the freon even be charged in this thing? (obviously by a pro not me). I turn the temp control (in freezer) sometimes when it doesn't seem cold and nothing happens (no kick on just a click where it should be kicking on or nothing at all)--yeah, i check to see if it is in defrost first. Today she is cold but as it gets warmer through out the day--so does the temp inside the refrigerator.
Maytag bottom freezer with ice frost in back and not freezing ice cream (Refrigerator & Freezer Repair)
by ricoscoro 10/2/2023 1:55:17 PM(UTC)
RF24R7201SR Samsung 4 Door French Door Smart Refrigerator not freezing (Refrigerator & Freezer Repair)
by kentuckynet 1/9/2023 1:54:17 PM(UTC)
Imperial heavy duty commercial freezer (upright) not freezing at bottom (Refrigerator & Freezer Repair)
by Guest 10/27/2022 11:02:21 PM(UTC)
GE PSB42YSXASS refrigerator not freezing (Refrigerator & Freezer Repair)
by Guest 6/13/2022 8:37:27 AM(UTC)
Samsung RM255LASH Freezer Not Freezing (Refrigerator & Freezer Repair)
by crbishop74 2/14/2022 6:45:02 AM(UTC)
LG not cooling/not freezing (Refrigerator & Freezer Repair)
by bradford702 11/13/2021 3:43:03 AM(UTC)
GX2FHDXVB00 whirlpool refrigerator freezer not freezing (Refrigerator & Freezer Repair)
by Nwhe54 12/21/2020 8:30:23 AM(UTC)
Viking Freezer not freezing but fridge is cool (Refrigerator & Freezer Repair)
by BgBrd 6/25/2020 11:41:34 AM(UTC)
Kenmore Elite freezer not freezing, but it is? (Refrigerator & Freezer Repair)
by colbran 4/24/2020 6:53:03 AM(UTC)
GE Profile French door - freezer not freezing (but fridge is!) (Refrigerator & Freezer Repair)
by annenap 2/26/2020 6:01:53 PM(UTC)
GE Freezer is not Freezing (Refrigerator & Freezer Repair)
by MrChip 10/23/2019 8:52:01 AM(UTC)
Frigidaire freezer side not freezing, fridge side not very cold (Refrigerator & Freezer Repair)
by tenlbham 4/13/2019 1:48:16 PM(UTC)
LG fridge LFC23760ST freezer not freezing, now fridge not cooling (Refrigerator & Freezer Repair)
by blairm 1/20/2019 1:40:44 AM(UTC)
Freezer not freezing after power outage (Refrigerator & Freezer Repair)
by otis732 10/8/2018 9:31:08 AM(UTC)
Samsung freezer, Very cold but not freezing (Refrigerator & Freezer Repair)
by stinkoman 8/21/2017 6:02:29 AM(UTC)
