I have replaced the thermostat, defrost element, and timer. The freezer is cold, but not freezing. The fridge is cool but not cold. the compressor is HOT to the touch. The fans are all working. There is a layer of frost on the elements when it is supposedly freezing that melts away when it goes into defrost. One day last week the food in the bottom of fridge was frozen--next day it was luke warm. What to check next?
THIS FORUM IS DEAD!!!!!!! |
Thanks. I think it is a mixture of both. Can the freon even be charged in this thing? (obviously by a pro not me). I turn the temp control (in freezer) sometimes when it doesn't seem cold and nothing happens (no kick on just a click where it should be kicking on or nothing at all)--yeah, i check to see if it is in defrost first. Today she is cold but as it gets warmer through out the day--so does the temp inside the refrigerator.
