3 Pages123>
turn543
#1 Posted : Thursday, March 13, 2008 2:06:43 PM(UTC)
turn543
My ice maker just quit working out on the blue. The refer has ice and water in the door and the water works fine. Could you please assist me? Thanks, Scott
#2 Posted : Friday, March 14, 2008 1:12:19 PM(UTC)
Hi Scott,
The first thing I would do: check if the shut off arm is in down position.
Then remove the head cover and check for 120V between the "L" & "N" test points.
If there is 120V - short the "T" & "H" with an insulated piece of wire to run the motor.
If the motor does not run - replace the module assembly or the whole ice maker.
If the motor runs - replace the thermostat.
Leave the jumper wire in for a half of a revolution and remove it. The water valve should be energized in the last half of the revolution.
Post your findings and I will provide the right part number(s).
turn543
#3 Posted : Tuesday, March 25, 2008 11:46:54 AM(UTC)
turn543
I found the water in the supply line in the top of the freezer to be froze. After thawing out wvwerything worked great. Thanks.
I did break the swing door on the inside left of the fridge that closes when the freezer door is closed, if you could help me with the part # that I can order. Thanks again.
#4 Posted : Tuesday, March 25, 2008 12:09:04 PM(UTC)
Good job!
The part number for the flipper is AP3037562
The flipper
UserPostedImage
barry 3
#5 Posted : Wednesday, May 27, 2009 2:40:17 PM(UTC)
barry 3
Hi Scott,
Gene,
ran 115 VAC through the solenoid valve and the ice tray filled and kept filling until power was removed. Waiting to see if ice is ejected into tray.
bg
turn543
#6 Posted : Sunday, May 31, 2009 6:32:57 PM(UTC)
turn543
my particular problem was related to the valve in the back on the bottom.I removed the hoses and checked the electrical connections and blew out the valve and lines and re-aasembled. After that everything worked well.All that I could figure is that there was some type of restriction and what I did corrected it. It has been working fine for about 6 months now.
barry 3
#7 Posted : Monday, June 1, 2009 10:52:37 PM(UTC)
barry 3
R2 The Ice Maker Assy And Works Fine Now.
Thanks For The Assist.
Regards/bg
#8 Posted : Monday, June 1, 2009 11:52:09 PM(UTC)
We are glad you were able to fix it.
smithb
#9 Posted : Saturday, June 20, 2009 3:57:33 PM(UTC)
smithb
Hi Scott,
I have a whirlpool GS6SHAXLS03 and my ice maker quit working (water feeds fine from the water dispenser). I followed the above instructions and am getting 35.5 VAC from the L/N connection. However, I do not know what the "shut off arm" is referring to. Do I just need a new motor then? Thank you for your help
#10 Posted : Saturday, June 20, 2009 9:53:35 PM(UTC)
Shut off arm is a metal wire arm on the right side of the ice maker which can be moved up to turn the ice maker "off" or down to turn it "on".
In your model there is an "on-off" switch on the right side on the wall. If the ice maker is "on" then it looks like there is no power to it. In such situation the problem most likely is a bad optics (#26 & #38 on the diagram)
- The part number for the optics board kit is AP3137510
Guest (11)
Ice Maker Quit Working (Refrigerator & Freezer Repair)
by dave2425 7/23/2012 8:45:20 AM(UTC)
Amana Ice Maker quit working (Refrigerator & Freezer Repair)
by modelships 5/9/2010 10:41:03 AM(UTC)
ice maker quit working (Refrigerator & Freezer Repair)
by Bill88 7/5/2009 11:00:21 AM(UTC)
Ice maker quit working (Refrigerator & Freezer Repair)
by 647sam 6/29/2009 8:54:42 AM(UTC)
by jayb 12/29/2008 4:44:28 PM(UTC)
by ptiso 6/29/2008 5:48:34 AM(UTC)
Water to ice maker quit working (Refrigerator & Freezer Repair)
by owenbrewer 6/4/2008 4:07:17 PM(UTC)
GE ice maker quit working (Refrigerator & Freezer Repair)
by dottiedrew 3/1/2008 6:42:03 AM(UTC)
3 Pages123>
