how do i take out front panel (one piece)
Take out the lint filter and the two screws that are there that hold down the top. Insert a putty knife or flat blade screwdriver into the front between the top and front panel at each end and the top will come up.
There are two screws that hold the front panel. Remove them and lift up and out on the front panel and it will come off. Be sure and disconnect the door switch (and reconnect it when you put the front back)
Good luck, let us know if you have any problems.
