#1 Posted : Saturday, June 20, 2009 2:51:29 AM(UTC)
There is no power to the fountain at all. Hope someone has seen this problem before, thanks in advance.
kayakcrzy
#2 Posted : Saturday, June 20, 2009 4:39:59 AM(UTC)
kayakcrzy
I was wondering if you checked the freezer liner switch. It must be a 2 position switch where there might be a possibility of the switch being bad, and the dispenser thinks the door is open, and it won't work. Therefor you would not get a volt reading there. That is my only thought. Of course I can't tell by the breakdown what type of door switch it is. Tom ApplianceEducator.com
#3 Posted : Saturday, June 20, 2009 5:06:19 AM(UTC)
Thanks for the info, will be working on it today, just might be the problem, will inform results.
kayakcrzy
#4 Posted : Saturday, June 20, 2009 5:18:23 AM(UTC)
kayakcrzy
Good Luck!! Tom
#5 Posted : Saturday, June 20, 2009 10:23:12 AM(UTC)
Just as you suspected, the door switch was bad, switch tested ok with ohm meter, but the dispenser worked when I jumpered the switch! Thanks again.
kayakcrzy
#6 Posted : Saturday, June 20, 2009 6:01:52 PM(UTC)
kayakcrzy
Awesome!!! Glad to help!! Sometimes the meter fools us. Tom Paone
