TominPA
#1 Posted : Thursday, June 18, 2009 8:40:44 AM(UTC)
TominPA
My dryer stopped working. It won't turn on. I noticed the power cord looked a little burnt and thought it shorted out so I replaced it and still nothing. Then I thought the start button might be bad so I ran a jumper across it and nothing. I took a reading of the voltage comming to the dryer and got 112 v. Is this normal for a dryer or do you think the breraker might be bad. Thanks for your replys. Tom
#2 Posted : Thursday, June 18, 2009 12:52:04 PM(UTC)
Hi Tom,
The complete model number of the dryer might help others to help you.
TominPA
#3 Posted : Friday, June 19, 2009 6:32:05 AM(UTC)
TominPA
The model # is RED4340SQ1. Any help out there? Thanks
Eddie365
#4 Posted : Friday, June 19, 2009 5:25:13 PM(UTC)
Eddie365
Hi. First check you are getting power to your outlet.
then check the door switch and make sure is closing properly or that is not broken.
Eddie365
#5 Posted : Friday, June 19, 2009 5:28:15 PM(UTC)
Eddie365
More over. You have an electric dryer so you should get 240v.
and check your thermo fuse is probably blown part # PS345113
Eddie365
#6 Posted : Friday, June 19, 2009 5:30:15 PM(UTC)
Eddie365
Part number on for thermo fuse is AP3132867 on this site.
TominPA
#7 Posted : Sunday, June 21, 2009 4:48:30 AM(UTC)
TominPA
Hi Eddie, Thanks for the reply. The problem was the outlet itself. One of the terminals was burnt out. Working great now. Have a good day.
Guest (4)
Roper dryer won't turn on need some help (Dryer Repair)
by Robdob363 2/2/2012 9:30:47 AM(UTC)
