Oven Igniter Will Come On But The Gas Is Not Lighting. Is There A Gas Regulator/timer?
Quote:Model Number: RGB525PEA5WA The closest model number I found a listing for was RGB525PEA 2W W. Can you double check it. Quote:oven igniter will come on but the gas is not lighting Is gas flowing into the oven burner? Any gas smells when turned on? If gas is not even flowing into the oven burner, that would just leave the ignitor and oven gas valve as possible culprits. Only an testing the amperage draw on the ignitor circuit will determine which might be the cause as explained at the following link. LINK > Understanding Gas Oven Ignition SystemsMost consumers wouldn't have an ammeter or amprobe tool to perform such a test. If you wanted to guess and hope for the best, the ignitor is the most common (~70-80%) troublemker in such a system, the oven gas valve the rest. LINK > Hotpoint RGB525PEA2WW Oven IgnitorLINK > Hotpoint RGB525PEA2WW Oven Gas ValveJMO Dan O. www.Appliance411.com The Appliance Information Site=D~~~~~~
Originally Posted by: Dan O.  The closest model number I found a listing for was RGB525PEA 2W W. Can you double check it. Is gas flowing into the oven burner? Any gas smells when turned on? If gas is not even flowing into the oven burner, that would just leave the ignitor and oven gas valve as possible culprits. Only an testing the amperage draw on the ignitor circuit will determine which might be the cause as explained at the following link. LINK > Understanding Gas Oven Ignition SystemsMost consumers wouldn't have an ammeter or amprobe tool to perform such a test. If you wanted to guess and hope for the best, the ignitor is the most common (~70-80%) troublemker in such a system, the oven gas valve the rest. LINK > Hotpoint RGB525PEA2WW Oven IgnitorLINK > Hotpoint RGB525PEA2WW Oven Gas Valve JMO Dan O. www.Appliance411.com The Appliance Information Site =D~~~~~~ CORRECT # RGB524PEA5WA. GENERALLY GAS IS NOT SMELLING, BUT THE IGNITER DOES GLOW SLOWLY AND THEN BRIGHTER. IS THER A CERTAIN TEMPERATURE TO BE REACHED BEFORE GAS FLOW?
Quote:Is ther a certain temperature to be reached before gas flow? No. As explained at the link previously supplied the ignitor must draw a certain amperage before the gas valve will open. Dan O. www.Appliance411.com The Appliance Information Site=D~~~~~~
I Replaced The Igniterbut The Gas Is Not Flowing After Over A Minute. ??? Thanks, Eustace
