eustlr
#1 Posted : Friday, June 19, 2009 8:06:06 AM(UTC)
eustlr
Oven Igniter Will Come On But The Gas Is Not Lighting. Is There A Gas Regulator/timer?
Dan O.
#2 Posted : Friday, June 19, 2009 9:11:04 AM(UTC)
Dan O.
Quote:
Model Number: RGB525PEA5WA
The closest model number I found a listing for was RGB525PEA2WW. Can you double check it.
Quote:
oven igniter will come on but the gas is not lighting
Is gas flowing into the oven burner? Any gas smells when turned on?
If gas is not even flowing into the oven burner, that would just leave the ignitor and oven gas valve as possible culprits. Only an testing the amperage draw on the ignitor circuit will determine which might be the cause as explained at the following link.
LINK > Understanding Gas Oven Ignition Systems
Most consumers wouldn't have an ammeter or amprobe tool to perform such a test. If you wanted to guess and hope for the best, the ignitor is the most common (~70-80%) troublemker in such a system, the oven gas valve the rest.
LINK > Hotpoint RGB525PEA2WW Oven Ignitor
LINK > Hotpoint RGB525PEA2WW Oven Gas Valve
JMO
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
eustlr
#3 Posted : Friday, June 19, 2009 10:29:21 AM(UTC)
eustlr
JMO
Dan O.
=D~~~~~~
CORRECT # RGB524PEA5WA. GENERALLY GAS IS NOT SMELLING, BUT THE IGNITER DOES GLOW SLOWLY AND THEN BRIGHTER. IS THER A CERTAIN TEMPERATURE TO BE REACHED BEFORE GAS FLOW?
Dan O.
#4 Posted : Saturday, June 20, 2009 8:42:48 PM(UTC)
Dan O.
Quote:
Is ther a certain temperature to be reached before gas flow?
No. As explained at the link previously supplied the ignitor must draw a certain amperage before the gas valve will open.
Dan O.
=D~~~~~~
eustlr
#5 Posted : Thursday, June 25, 2009 7:05:52 AM(UTC)
eustlr
I Replaced The Igniterbut The Gas Is Not Flowing After Over A Minute. ???
Thanks, Eustace
Dan O.
#6 Posted : Thursday, June 25, 2009 11:02:08 AM(UTC)
Dan O.
Quote:
replaced the igniter but the gas is not flowing
Is the ignitor is glowing?
JMO
Dan O.
=D~~~~~~
