My dispenser quit working. I have no lights on the door buttons.
No one has seen this problem? Should I start with a motherboard?
New motherboard same problem....any suggestions?
Check the wire harness to the freezer door (on top or on the bottom of the door). Disassemble the dispenser front panel (instructions attached) and check all connections. If there is nothing wrong then the dispenser board most likely is the problem. For the correct dispenser board part number post the color of it. Gene.
