easymoney
#1 Posted : Wednesday, June 10, 2009 8:23:22 AM(UTC)
easymoney
My dispenser quit working. I have no lights on the door buttons.
easymoney
#2 Posted : Sunday, June 14, 2009 3:22:12 PM(UTC)
easymoney
No one has seen this problem? Should I start with a motherboard?
v-man
#3 Posted : Tuesday, June 16, 2009 9:48:24 AM(UTC)
v-man
#4 Posted : Tuesday, June 16, 2009 11:28:39 AM(UTC)
Most likely the problem is a bad main control board on the back of the refrigerator.
- The part number for the main control board is AP4297272
Here are the breakdown diagrams and Replacement parts for GE DSS25KGRAWW | AppliancePartsPros.com
easymoney
#5 Posted : Wednesday, June 17, 2009 1:14:27 PM(UTC)
easymoney
New motherboard same problem....any suggestions?
#6 Posted : Wednesday, June 17, 2009 4:36:48 PM(UTC)
Check the wire harness to the freezer door (on top or on the bottom of the door). Disassemble the dispenser front panel (instructions attached) and check all connections. If there is nothing wrong then the dispenser board most likely is the problem. For the correct dispenser board part number post the color of it.
File Attachment(s):
How to open ice dispenser.doc (97kb) downloaded 57 time(s).
