sframser
#1 Posted : Wednesday, June 17, 2009 4:29:16 PM(UTC)
sframser
Oven heats and works fine. only 1/2 of the broiler element gets hot.
I've replaced the broiler element but the problem persists.
Any suggestions?
Dan O.
#2 Posted : Thursday, June 18, 2009 12:40:15 PM(UTC)
Dan O.
The broil element on that model consists of two separate element coils.
LINK > Jenn-Air W130 Broil Element
If just one of those coils is not heating and element failure is not the cause (since a brand new one works the same), there could be a problem in the wiring leading to that side of the element or maybe in the control that powers it. Some actual investigation would be required to determine which (if either) might be the cause in your case.
JMO
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
sframser
#3 Posted : Thursday, June 18, 2009 4:29:06 PM(UTC)
sframser
Thanks Dan,
I replaced the original element because it wasn't working. The exterior 'skin' of the element had blistered and turned gray.
The replacement unit will not heat on the right hand portion of the element, the same position that originally failed.
all other functions work well i.e. clock, lights, timers, oven and 75% of the elements required for the cleaning cycle.
Where and how do I proceed?
Dan O.
#4 Posted : Tuesday, June 23, 2009 1:29:26 PM(UTC)
Dan O.
I would imagine checking the wiring for that side of the element would be a good place. Next might be following that wiring back to the control to see if there's anything in that circuit which could be responsible for stopping the power (and/or checking the appliance's wiring diagram).
JMO
Dan O.
=D~~~~~~
Guest (4)
