cherylb
#1 Posted : 16 years ago
cherylb
my light under the built in microwave doesn't work -ried to replace bulb that isn't it -he wire also turns the turntable and that works fine any suggestions?
#2 Posted : 16 years ago
Remove the bottom panel, disconnect the wire harness plug to the lights and check for 120 VAC to the surface lights while the control calls for lights.
If there is no proper voltage then the control board has to be replaced.
- The part number for the control board is AP3892569
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL MH1170XSY0 | AppliancePartsPros.com
Whirlpool WRF757SDEM01 led light problem (Refrigerator & Freezer Repair)
by Guest 12 months ago
confusing light problem (Refrigerator & Freezer Repair)
by BryceB 9 years ago
Microwave hood light problem (Microwave Repair)
by Adamsck 12 years ago
florescent light problem (Microwave Repair)
by jltnak 12 years ago
Interior Light Problem (Refrigerator & Freezer Repair)
by Judah 12 years ago
Oven light problem (Oven Repair (including Ranges and Cooktops))
by lookwin 14 years ago
GE Midrowave bright light problem (Microwave Repair)
by richard.csongor@gmail.com 16 years ago
Propane pilot light problem (General Talk)
by jcapaci 16 years ago
Litton oven selection light problems (Oven Repair (including Ranges and Cooktops))
by Laynechain 17 years ago
Whirlpool Conquest Light Problem (Refrigerator & Freezer Repair)
by New Guy 17 years ago
