cherylb
#1 Posted : Wednesday, June 17, 2009 1:10:41 PM(UTC)
cherylb
my light under the built in microwave doesn't work -ried to replace bulb that isn't it -he wire also turns the turntable and that works fine any suggestions?
#2 Posted : Wednesday, June 17, 2009 4:24:16 PM(UTC)
Remove the bottom panel, disconnect the wire harness plug to the lights and check for 120 VAC to the surface lights while the control calls for lights.
If there is no proper voltage then the control board has to be replaced.
- The part number for the control board is AP3892569
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL MH1170XSY0 | AppliancePartsPros.com
Whirlpool WRF757SDEM01 led light problem (Refrigerator & Freezer Repair)
by Guest 3/16/2024 1:02:12 PM(UTC)
confusing light problem (Refrigerator & Freezer Repair)
by BryceB 9/6/2016 9:27:19 AM(UTC)
Microwave hood light problem (Microwave Repair)
by Adamsck 2/25/2013 1:58:08 PM(UTC)
florescent light problem (Microwave Repair)
by jltnak 10/24/2012 7:18:37 PM(UTC)
Interior Light Problem (Refrigerator & Freezer Repair)
by Judah 10/8/2012 12:38:09 PM(UTC)
Oven light problem (Oven Repair (including Ranges and Cooktops))
by lookwin 5/11/2011 4:23:20 PM(UTC)
GE Midrowave bright light problem (Microwave Repair)
by richard.csongor@gmail.com 3/21/2009 4:11:36 PM(UTC)
Propane pilot light problem (General Talk)
by jcapaci 1/12/2009 1:04:29 PM(UTC)
Litton oven selection light problems (Oven Repair (including Ranges and Cooktops))
by Laynechain 1/31/2008 3:35:29 AM(UTC)
Whirlpool Conquest Light Problem (Refrigerator & Freezer Repair)
by New Guy 12/12/2007 5:58:41 PM(UTC)
