redwolf2130
#1 Posted : Tuesday, June 16, 2009 10:06:02 AM(UTC)
redwolf2130
Microwave unit makes a noise like birds chirping when running. When used for several minutes it powers off and remains off for 5 or 10 minutes. It can then be re-started and will continue to work with chirping sound until unit again powers off. Any idea what part may be causing this?
Thanks...
#2 Posted : Tuesday, June 16, 2009 11:59:30 AM(UTC)
The first thing I would do is check the cooling fan (#79 on the diagram). Sounds like the magnetron overheats.
Here are the breakdown diagrams and Replacement parts for GE JVM1650SH04 | AppliancePartsPros.com
redwolf2130
#3 Posted : Tuesday, June 16, 2009 2:18:03 PM(UTC)
redwolf2130
Hi Gene and thanks for getting back to me. How can I check out the fan without actually purchasing a new one? Also how do you get to the fan?
Thanks again!
#4 Posted : Tuesday, June 16, 2009 5:12:28 PM(UTC)
You have to remove the top grill and open the control panel. First check the fan blade is in place and check the fan motor for continuity. If there is nothing wrong then turn the microwave "on" and see if the fan works.
redwolf2130
#5 Posted : Friday, June 19, 2009 6:06:12 AM(UTC)
redwolf2130
Gene, The fan is what's making the noise. I'll go ahead and order a new one. Any tips on the installation.
Thanks so much for your help. Your diagnosis of the problem has been excellent.
George...
#6 Posted : Friday, June 19, 2009 9:53:25 PM(UTC)
George,
I'm afraid you'll have to remove the microwave from the cabinet to replace the fan motor.
Guest (4)
