I have a Whirlpool Dishwasher Quiet Partner III, serial number FM1030740, Type 575-0. It will not run. I have changed the thermal fuse and both door switches; still won't run. I have power from the house and I read power to the door switches; 103 VAC on the right and 3 VAC on the left. Any ideas?
Joe Emperly:confused:
130 VAC could be not enough for the dishwasher.
Check the voltage from the outlet and check the wires in the junction box under the dishwasher.
Good luck. Gene.
